Switching From 6 volt Generator to 12 volt alternator
Posted by HY_Moose on January 09, 2009 at 16:39:50 from (173.23.142.226):
I know I need to change the battery from a 6 positive to a 12 negative ground. I also need to either change the coil or put a resistor in front of it and bypass the regulator with the new single wire alternator. What about the points? I will need to change the lights. What else?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
