Posted by El Toro on January 09, 2009 at 18:34:03 from (205.188.116.73):
In Reply to: 400 grief posted by Dodger on January 09, 2009 at 14:58:28:
Hold your hand over the throat of the carburetor and see if there's good suction. Low suction is an indication of low manifold vacuum. You need good manifold vacuum to suck that fuel into the engine. Make sure the intake manifold is snug. Do a compression check and compare the readings. Worn sleeves, rings and valves not seating all contribute to low manifold vacuum and low compression. Make sure you have the plug wires in the correct firing order on the cap and to the plugs. Should be like this on the cap. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
