Posted by bc on January 10, 2009 at 08:20:21 from (68.88.175.43):
In Reply to: 404 not getting fuel posted by Bill Chapman on January 09, 2009 at 16:59:35:
Bill, a common problem. Run for 5 minutes and quit. Then the carb fills up and it restarts again. Main test is to remove the fuel line from carb, run it through a hose into a gas can or bucket for 10 minutes or 5 minutes longer than what it runs. Need a good steady flow. Even with new sediment bowl, you still get chunks of rust in the tank that settles around the bowl intake and blocks the flow and you may not see much in the bowl. Basic fix would be to put a 1 to 2 inch piece of screen or plastic/rubber hose on the bowl intake nubbing sticking up into the tank. It also keeps the water on the bottom of the tank from getting in.
Otherwise I'd be for changing the condenser and coil. The coils can be weak or a winding go bad and not get hot after long running.
Post back with your results and let us know. I'm leaning towards a rust problem first. If you have even just a few rust fines in the bowl, you can count on some big chunks in the tank.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
