Yes, a pin in the cylinder linkage under the cylinder allows float or down pressure
The 450 had a marginally operational draft control (not ideal) the 400 had a cylinder controlled angle of attack control that was difficult to make work (learn to finesse) as draft adjustment, but worked well to get equipment well off of the ground. The above means it is a toss up and not equal but different. The added cylinder on the 400 uses a valve to control the cylinder that leaves only one of possible three open for remotes.
Very few components will interchange (memory) due to different structures/castings/sizes. Check part numbers on caseih.com for possible interchange. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
