Re: Workin 300U
Posted by rumplestiltskin on January 10, 2009 at 14:58:59 from (96.12.150.70):
In Reply to: Workin 300U posted by Dellbertt on January 10, 2009 at 10:14:49:
Hi, Dell.
Where are you from in SW Michigan?
I'm a little NE of Rockford (Grand Rapids area), and also own a 300 Utility -- although it's currently in pieces (undergoing a nose-to-tail redo).
Mark W. in MI
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
