First off change the hyd. filter and make sure that the hyd. oil is not milky looking .check fluid level and make sure that you are up to the full mark . Next run the tractor for about a half hour and then try turning the steering wheel to the left while running the engine up around 1500-1800 and see if she will pick up prime . Then the other thing it could be is that the Flow control valve maybe sticking . Also is the dash lite working that comes on when ya push down the clutch pedal ??? if not put a new bulb in it . IF the lite stays on after the clucth pedal is up then she is not picking up prime to the MCV pump , Then try adding three to five more gallon of Hy Tran to the system and see if this helps. If all of the above does not help then you will have to either get a I T manual and LEAN ALL ABOUT THE MCV or let someone that does get into it.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
