Re: rust stuck engine
Posted by El Toro on January 10, 2009 at 18:04:01 from (205.188.116.73):
In Reply to: rust stuck engine posted by rrogers on January 10, 2009 at 13:12:21:
You can drive them out from the bottom using a piece of 2 X 2 oak and a big hammer. The sleeves aren't pressed into that block. I pulled the engine on the A I had that was stuck so you don't need to lay under the tractor. The block probably needs cleaning too. Hal
