Re: rust stuck engine
Posted by John A. on January 10, 2009 at 21:29:37 from (138.210.118.138):
In Reply to: rust stuck engine posted by rrogers on January 10, 2009 at 13:12:21:
rrogers, Here goes, follow my instructions....
1 remove all tinwork, gas tank, intake/exhaust, and head, pan and oil pump, and rod caps.
2 roll tractor outside, remove all flammable materials. be sure you are not too close to shead roof or anything flammable.
3 into the cylinder pour Diesel with a splash of gas, set mixture on fire. Go get a cup of coffee...., let fire burn itself out, now drive out piston from the bottom.
Note if the volume of this cylinder is some what small compared to the rest it may take 2, 3, 4, or more times to get the cylinder to expand enough to get the piston to turn loose.
Hope this helps.
Later,
John A,
