Re: 130 tranny pic
Posted by Gene Bender on January 10, 2009 at 23:34:43 from (67.55.226.75):
In Reply to: 130 tranny pic posted by EZ on January 10, 2009 at 18:23:02:
Dont worry about the slinger inless you will be using the pto as it throws the oil for the pto. Early model As Bs didnt even have the slinger gear. Tranny probably had some moisture at some time and froze or those teeth wouldnt be broken as the gear is some sort of pit metal. Used ones usually run around 60 and you dont want to hear the price of new.Those other gears will last a long time if anything needs to be changed it would be the input bearing and seal. I would use 150wt gear lube it will quiet it down a bunch.
