Re: How to time a Distributor?
Posted by Gene Bender on January 10, 2009 at 23:59:19 from (67.55.226.75):
In Reply to: Re: How to time a Distributor? posted by Garry in TENN on January 10, 2009 at 21:39:41:
That mark will be at the most bottom position when the flywheel turns. The timing mark will be on the cover at the front of the bellhousing and the original pointer used could aslo be gone as both were used from model to model and after all these yrs who would know if yours is all original. Bottom is TDC. You are luck that its marked.
