Re: converting H to 3point hitch W /hydraulics
Posted by Allan In NE on January 11, 2009 at 02:35:21 from (148.78.243.24):
In Reply to: Re: converting H to 3point hitch W /hydraulics posted by john d on January 10, 2009 at 19:21:56:
John,
This is another of those old-wives tales.
The "delay" on that left rear-facing port is in the drop, not the lift. Hence, the reason for the detent on the "lowering" side of the lever.
However, all three ports are plumbed to the same pressure feed for lifting.
In order to get a delay on any of the ports, an external restrictor has to be used in the line.
Allan
