Posted by Mike Farmer on January 11, 2009 at 03:45:30 from (81.107.143.138):
In Reply to: rust stuck engine posted by rrogers on January 10, 2009 at 13:12:21:
Remove head and sump/pan. Undo conrod bearings so the bottom end is loose. Soak for as long as you like. Then using a FBH and a block of 2x2 HARD wood start to drive them down ward. This way you wont move the sleeves. But you must be careful not to drive them so far the the bottom ring goes past the sleeve end. Until you get to this point you cant tell how many pistons are actually stuck or to what degree. Even with a certain amount of pitting in the sleeves the worst is you burn a drop of oil until the pits coke up.(obviously not if the pits are serious) Good luck. MTF
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
