Re: cub doesn't like to start in sub-zero
Posted by OLDIRON29 on January 11, 2009 at 05:21:14 from (69.123.78.107):
In Reply to: cub doesn't like to start in sub-zero posted by kennebunksawmill on January 11, 2009 at 05:02:18:
Kenbunk,I have had the same problem with a cub.
Yesterday snow was comming so I went out to put the chains on and get her going. I have 3 cubs parked in same shed. 2 of them start with no problems the one with the snow plow would not. I ran battery down and had to charge it. I pulled mag cleaned points spark is good it seems to be fuel problem gas running out of carb but plugs are dry. I am going to pull carb today clean and change my plug. Mabe swap carb with other cub see if that changes anything. oldiron29
