Re: Super A smoking
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Dave on April 03, 2000 at 12:38:06 from (128.113.2.54):
In Reply to: Super A smoking posted by p on April 01, 2000 at 16:41:14:
You could do a dry, then wet compression test to rule out the rings for sure. Check the compression as-is, then again after adding a tablespoon of oil to each cylinder. If it improves, the oil has helped seal bad rings. If it stays the same, the rings are good and the valves are to blame.
Post A Followup
: Re: Re: Super A smoking
