Re: cub doesn't like to start in sub-zero
Posted by Dave in CT on January 11, 2009 at 09:33:26 from (69.182.107.227):
In Reply to: cub doesn't like to start in sub-zero posted by kennebunksawmill on January 11, 2009 at 05:02:18:
Another thought, triggered by the accounts of black smoke, is to see if your float is closing. Before doing anything, pull the hose from the air intake off to see if gas runs out. If it does you're flooding by the float valve not closing. I haven't solved the float problem on my H so I shut the fuel off before I stop the engine using the valve at the sediment bowl. I would imagine similar issues would be possible on the cub. Once that's done the blipping the choke techniques described here tend to work a lot better.
