Re: 1586 slips out of reverse
Posted by the tractor vet on January 11, 2009 at 11:57:04 from (75.19.124.16):
In Reply to: 1586 slips out of reverse posted by michigan john on January 11, 2009 at 10:51:30:
Well the first place i would take a peak at it the rev shift fork . ya can do this by removing the cover with the clipped corner on the left side or the rear end housing behind the steps , you will loose about a gallon of hy tran when ya pull this cover . check and see if by chance that maybe that shift fork may have broken one of the ears off and if so a bit more tear down will be required to fix it.
