A diesel take a bit to warm up as she has to make her owen heat and a diesel need to be above 165 degrees to start burning all the fuel now i am taking water temp. here. Now not seeing the tractor it also maybe pump timing or your injectors may be slobering , this problem is something that you are not equipped to handle . and if you are not use to working on diesels then let a pro check it . Engine compression could be low due to being plum wore out to broken rings from someone putting either to it to start it or could be that someone did a valve job on it and did not do it correctly and set the valves to deep into the head and this will also cause low compression and smoking .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
