Super M Water Pump
Posted by Darin Doescher on January 11, 2009 at 14:45:17 from (75.173.169.144):
How tight do you tighten the packing nut on the water pump to prevent leaking. Currently, old packing leaked tightened nut, still leaked. Re packed with ne w packing, still leaks. I am using OEM packing, but still get the leak. It only leaks when the tractor is shut off. When running it is fine. Any ideas, thoughts or suggrestions would be appreciated.
