Posted by Janicholson on January 11, 2009 at 15:41:44 from (68.112.156.69):
In Reply to: lift and tires posted by rrogers on January 11, 2009 at 14:22:42:
A low profile wider tire is best. You should try to avoid any increase in total outside diameter. The tractor has a first gear that is already fast enough. Wide good tall bad. Use a tire to rim ratio designed for the tire, or the tread will be pooched out and not get proper traction. Suggested rim width is usually marked on the tire. JimN
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
