Re: H Stuck rear wheels
Posted by Janicholson on January 11, 2009 at 15:46:44 from (68.112.156.69):
In Reply to: H Stuck rear wheels posted by catfish-65 on January 11, 2009 at 15:06:25:
80/20 Frozen water 80% chance
If band brakes (likely) they are easy to get at to check. If disk pretty easy also. Looking into the front hole of the disk brake with a small light while someone pushes the pedal can see internal action.
Pull the plug on the rearend and as it comes out of the hole, ba slow. I bet you find ice. Warm it and then drain it. Do not drive it, things can break, and it will mix the H2O with the oil. Just draining the water will make other assessments possible. JimN
