Re: Allied Precision Hydraulic Filter Extension, WOW!!!!!!!!
Posted by bc on January 11, 2009 at 16:08:03 from (68.88.175.43):
In Reply to: Allied Precision Hydraulic Filter Extension, WOW!!!!!!!! posted by charles todd on January 10, 2009 at 20:27:12:
Thanks Charles, I've been looking for one of those. My dealer and the case website doesn't even show the parts for the dual filters anymore. They don't even stock the thicker single filter and said they haven't sold any in years and years. They didn't carry any adaptor either.
CaseIH calls for the single 388084R93 filter for the 12 gpm pump. Wix number is 51469. The filter thickness is 2.473 inches and rated at 25 microns.
CaseIH calls for the single 388085R92 filter for the 17 gpm pump. Wix number is 51470. The filter thickness is 3.597 inches and rated at 35 microns.
The thicker one is about 1.124 inches thicker and I assume that is about how thick your spacer is.
Wix makes filters with a metal outside surface instead of the paper surface of the case filter for what that is worth to anyone. Less chance to tear up and end up in the pump. At O'reillys they are a little cheaper also but may need a day to ship if not in stock.
My question is about putting some type of gasket cement on one side so it stays stuck and then you only need to change one gasket with the filter? And then which side would be best to stick the adaptor on, the tractor or the cover plate? Guess I'd go to the tractor side.
(technically, I've never replaced the gasket but just bolt the plate back up and it doesn't leak. The gasket is stuck to the plate. The spring of the bypass pushes the plate away.)
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
