Re: 1086 hyd couplers
Posted by scotc on January 11, 2009 at 16:40:09 from (204.110.227.11):
In Reply to: 1086 hyd couplers posted by Adam W in So. Il. on January 11, 2009 at 13:18:19:
Does the 1086 have the blocks like the 966 where the hoses plug in or were they replaced with generic female ends?
If they were replaced you can get a set of junkyard blocks and it wouldn't take much to make a set of brackets and replace them.
If the block is there and the levers are busted off, check with CIH, but you may be better off getting the complete assembly from the junkyard, then you can pull the innards out of them, replace a couple o-rings, and put them in the current blocks, and be good to go. Remove a snap-ring and they pull right out.
It sounds to me like the IH outlets were replaced.
