Re: Pullin' the Pully......Super A
Posted by P and R Pete on January 11, 2009 at 16:56:42 from (159.240.11.254):
In Reply to: Re: Pullin' the Pully......Super A posted by Janicholson on January 11, 2009 at 15:36:58:
I had my crankshaft cleaned by a machine shop when they checked for cracks and ground the journals, and the pulley cleaned before a small crack was welded. That, and heating the pulley to 200 degrees, (didn"t want to go hotter, afraid of ruining the new seal) and as Mr. Nicholson said, it went on real easy.
Don"t forget the key.
