Re: Farmall 140 tractor
Posted by Hugh MacKay on January 11, 2009 at 18:46:16 from (209.226.106.150):
In Reply to: Re: Farmall 140 tractor posted by d bridgers on January 11, 2009 at 17:47:39:
d bridges: I can help you a bit based on that engine serial number. Your tractor is a 1958 or 1959 model, probably around the 2500 th one built. 140 and 240 used a common sequence of engine serial numbers. 140-501 had engine 65046, F240-501 had engine 65032 and I240-501 had engine 67017. I'm assuming there were as many 140 as F240 and I240 combined or close.
Your casting date codes should be D for 1958 or E for 1959.
