Re: lift and tires
Posted by Gene Bender on January 12, 2009 at 03:53:13 from (67.55.226.75):
In Reply to: lift and tires posted by rrogers on January 11, 2009 at 14:22:42:
The lever is either the lift for an A-134 Cult or for the rear tooling on the A-138-437. Needs to be turned the other way to see how it mounts. There were several thpes of handles for lifting the different implements used on the A. I have lifts for the plow and three types of cults used on the A. I have an A-134,A-138 and the A-437 cults with different rear tooling set-ups. The standard tire for an A was 8x24 on 7in rim. 9x24 on 8in rim. If you have the 8in rims the new 9.5 looks and mounts great. If traction is a big thing then mite want to go to 10in rim so you can mount 11in or bigger rubber. The 9.5 with one wt seems to be fine for me.
