Re: Intermittent spark C-123
Posted by Brownie 450 on January 12, 2009 at 09:31:56 from (216.51.158.151):
In Reply to: Intermittent spark C-123 posted by DRC on January 12, 2009 at 09:00:19:
First check would be in the distributor--look for any connections/ wires that might touch the case- causing a ground situation. Second check should be the feed-through bolt on the side of the distributor housing. this has the short wire attached coming from the coil. Inside the distributor housing, the movable point contact is connected to it. Should be electrically isolated from the distributor case [not grounded]. One other possibility is a bad condenser--even new ones can be faulty.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
