Posted by pete 23 on January 12, 2009 at 10:27:25 from (74.47.40.94):
In Reply to: 656 fast hitch lift posted by tuck on January 12, 2009 at 09:55:08:
Hitch has own hyd pump and when hitch is in neutral the flow from that pump joins flow to aux valves from other pump. There is an unloading valve in draft control block that dumps this fluid to the aux valves system when hitch is in neutral. Try holding your aux valve lever to your loader until the cyl reaches end of stroke and keep holding it on demand and see if hitch will raise then. If it does the unloader valve is the problem. Also hitch has seperate relief valve and along with draft control valve they are in the compartment under the seat.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
