Re: International 464 Diesel Smoking?
Posted by pete 23 on January 12, 2009 at 10:50:57 from (74.47.40.94):
In Reply to: International 464 Diesel Smoking? posted by Tyler Gills on January 11, 2009 at 10:47:32:
The german engines are the stinkiest around. Many years ago, our service rep told us a dairy farmer had taken IH to task as he claimed it was making his cows sick. IH did a lot of changing on these engines, most important one was to put in different pistons to raise compression ratio and changed the tips on the injection nozzles to what they called a low sac tip or something like that to dercrease the volume of fuel hanging in the tip of the nozzle after injection . These changes helped a lot and also made it so the valve recession in head was not nearly so critical. Using a lighter fuel in cold weather really helps the slobbering situation also, just burns easier. On the starting procedure, well, there was a B and C series inj pump, and they required different procedure for starting. Not that one was better, just different. They are still stinky though.
