Re: Allied Precision Hydraulic Filter Extension, WOW!!!!!!!!
Posted by charles todd on January 12, 2009 at 15:06:09 from (205.242.95.141):
In Reply to: Allied Precision Hydraulic Filter Extension, WOW!!!!!!!! posted by charles todd on January 10, 2009 at 20:27:12:
Karl F, Thank you for the kind words of concern and wisdom. You do not post as often as some, but when you do it usually has purpose. I thumbed my IH TC-88 parts maunal for the correct "stock" filter and found none for the 17 GPM pump, but found the pump. My dealer said the "donuts" would work for both. I have since quit using that CNH dealer since the Branson/McCormick dealer closer to me is now an IH parts dealer, much brighter guy.
As for my plumbing... I chose to go the route I went for simplicity. I did not have to alter ANY steel lines. Yes, you warned me against using the plumbing path I drew out because the power beyond valve would take priority from the steering when activated. The steering does fade while using a PB valve, but I have learned to circumvent this by planning my movements. It is rare I am turning and using the loader at the same time. Besides, as fast as the loader is now I do not have to be moving and cycling the valves to save time. I dare to say it is faster than most NEW OEM systems! Sometimes it is almost too fast! Well, never too fast.
Karl F, I do not know if you saw the plumbing arangement on the PB valve body its self or the return lines. I can post pics later if you would like. I used open centered (non poppet) qiuck disconnects and alternated the male and females so I could remove the valve tower completly if required and restore the OEM system if need be. For general use, I can just unplug the 4 - 1/2" qd's from the loader lines and be out in 10 min flat.
An external pump and reservoir would have been a PITA from the get go... Sorry Allan NE, and others that suggested that one, I did not agree with that one bit. I think my total cost in pump, fittings, hose, valve, steel, ect for the hydraulic redo including "freebe's" was about $500-$600, plus the $3800 for the loader. Grand total of about $4400. I feel it was worth it even if it was worth more than the old 504 itself :twisted:
I have been looking at various OEM designs from the past and wonder "what the heck?" Being an Engineer myself I tend to look deeper into things than required. I am proud of my creation. And I am glad I have motivated and inspiref others as well.
The reason I am so chatty is that I was burning a brush pile Sunday and jammed a limb into my eye... I am on meds and at home during working hours... My wife would beat me if she knew I was not resting :D I would rather be sharing info here!
Thanks guys, with out ya'll I would have scrapped that dang 504 years ago.
Charles
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
