Re: Farmall M running poorly
Posted by CSK on January 12, 2009 at 18:50:59 from (70.39.18.196):
In Reply to: Farmall M running poorly posted by CSK on January 08, 2009 at 21:20:10:
Thank you to all that replied as I got the tractor running again this evening! I drained the gas and added fresh, cleaned the plugs as well as the carb and sediment bowl. I then set the screws on the carb according to a post I read on here- main jet out 2 1/2 turns and idle mixture out 1 1/2 turns. The tractor started after some cranking and it had gas running out the carb before it fired up. It runs okay but sometimes when the throttle is opened quickly it will pop and put a little fire out the exhaust. I don't know much about adjusting them so was wondering if anyone had any advice on where to go from here?
I still plan to retorque the head bolts and set the valve lash. Thanks to all who replied- the help was greatly appreciated.
Thanks,
Cory
