Re: F20 leak
Posted by Kevin LA-CA on January 12, 2009 at 18:55:22 from (173.51.84.53):
In Reply to: F20 leak posted by cowboy1939 on January 12, 2009 at 10:45:53:
On my regular I installed lip seals on the PTO & belt pulley shafts. It might work on the input as well.
Measured OD of shaft & ID (minor diameter) of casting on tractor. Use a bearing house to find a good match. Gooped up the seal OD with silicone and pushed it in. Then cut a ring from large pipe that approximated the seal OD. Put the in ring in, and then the packing nut to hold seal in place.
Hope this explanation makes sense. Wish I had a photo, but can try to walk you thru it if you need.
kevin
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
