Re: Pullin' the Pully......Super A
Posted by Gene Bender on January 13, 2009 at 01:04:03 from (67.55.226.75):
In Reply to: Re: Pullin' the Pully......Super A posted by Wild Bill Caldwell on January 12, 2009 at 06:22:28:
Ihave had lots of experience of press fitting but in this case the heat wont do the new seal any good. Your dealer should be able to get a seal that has Viton for the rubber and it is good to around 300. I would press the pulley on. I made a bracket sort of to use a hy jack and press them on. It wont hurt to heat the pulley to around 200. I do polish the pulley and shaft good and of course a coating of oil on both.Some do have a tighter fit than others as we are talking about a thousand or so. Putting some ice on the shaft wont hurt a bit as metal expands something like 6 to the 7th power per inch per degree. I used to fit dies for extruding lead and aluminum making tubes for toothpast and other products.
