Re: 354898 SPECs
Posted by the tractor vet on January 13, 2009 at 07:45:24 from (75.19.124.16):
In Reply to: 354898 SPECs posted by Wild Bill Caldwell on January 13, 2009 at 06:36:01:
How thick are the 3 1/4 sleeves at the bottom?? like i said before take a little off the area of the sleeve where is goes into the bottom counter bore and a little out of the block and allow for a .001 interference fit and press the sleeves into the block BUT one must make sure that when doing this that you have proper sleeve STAND OUT at the top and that the upper counter bores are dead on or you will have head gskt problems in the end. Ya need to do a lot of figuren before ya push the start button . I can not see why you can not get your mic.'s down in there to get good reading . Either with a telescoping mic. or and inside mic.or a bore gauge . Myself i like to rate a job on how may 12 packs it would take to do it and this one would be around three . from start to finish . Now if my one buddy still had his machine shop this whole deal on his stationary boring bar would only take about and hour and a half . As to what the books say i can't tell ya as all mine are out at the farm.
