Re: Repower Virtualy Any IH/Farmall with a CUMMINS!
Posted by the tractor vet on January 13, 2009 at 08:05:06 from (75.19.124.16):
In Reply to: Re: Repower Virtualy Any IH/Farmall with a CUMMINS! posted by Hugh MacKay on January 13, 2009 at 04:42:10:
Ya know Hugh that as long as i have been around I H's ya never find two of them that are the same from the factory . And this holds true to all engines . A 5.9 cummins with a turbo will run the bag off a D360 or a DT 360 hands down unless the D360 had the wick turned up and there was a problem with the 5.9 , So with out putting BOTH tractors on the same Dyno and RUNNING The same test on both ya can not be 100% sure as to why the D360 out preformed the 5.9 Did both tractor weigh the same did they both have the same tires . Now will a 5.9 hold a candle to DT466 yes set at the same hp. setting yes as they run the 5.9 in med. duty trucks and set at the same Hp. the 5.9 puts out MORE torque . As to how long they will live hey thats a craps shoot . Why did Case I H use the 504 well my thinking on this is more cubes more torque . Bigger block more built in weight . Also they do not have to turn up the fuel as high to get the desired Hp. Less fuel to the engine better fuel econ. and longer engine life. Plus with them going to and OUT SOURCED engine they no longer have to put up with the EPA and there goofy ideas . No more problems with air pollution from the foundry no getting and engine cert. for the clean air act let someone else worry about it.
