Posted by Janicholson on January 13, 2009 at 18:10:53 from (64.83.227.252):
In Reply to: Re: MW 9 speed posted by Wardner on January 13, 2009 at 17:49:42:
With respect, and I do respect your judjment and ideas!!, A standard M pinion has a splined brake shaft running out the end into the brake housing. The differential drives the pinion gear directly. The M&W pinion is hollow, and driven from the outside. In the hollow center is a shaft that is driven by the differential, and extends through the pinion to the outside. The M&W clutch locks the pinion to this shaft, driving the pinion at 1:1 with the differential. The only thing the clutch does is allow the pinion to be disconnected from the differential. When the M&W clutch is disengaged the differential turns freely (spiders tumbling M&W shaft turning, and the disconnected pinion stopped) In my "Mind's eye" setup a set of gears would allow the pinion to turn much (or a little) slower. thus reducing the total gear ratio. It could also increase the ratio. It would be nice to use pre-engineered gears to make this "box" so ratios could be changed. The down side would be the wear on the differential, because it would be turning all the time (as though having a tire 70% smaller on one side. But for pulling, or creeping, I think it would be irrelevent). Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
