Re: MW 9 speed
Posted by superih on January 13, 2009 at 19:16:08 from (206.53.144.121):
In Reply to: MW 9 speed posted by MCMP on January 13, 2009 at 10:41:06:
You will need the entire bottom shaft with gears, the top input shaft (preferebly the entire input assembly) at least the forth/fifth slider (it is different than stock and if you get all slider gears the tranny will run without wining) and the shifting assembly. The shifter swings on a pin that goes through the hole of the reverse idler where normally there is a bolt that holds the reverse idler shaft from turning in its bore. You will need to drill this hole out. It is not a hard swap to do, and even easier if you take it out of the donor tractor so that you can see how it all goes together.
Good luck
