Re: Farmall H Battery Installed backwards
Posted by K-Mo on January 14, 2009 at 05:13:53 from (65.169.189.2):
In Reply to: Farmall H Battery Installed backwards posted by Antgre on January 14, 2009 at 04:46:10:
1. Reconnect the battery with positive to ground.
2. Polarize the generator. To do this momentarily touch a jumper across the "BAT" and "GEN" terminals of the regulator.
3. Check the coil connections. On a positive ground system, the "+" terminal on the coil should be connected to the distributor.
K-Mo
