Re: MW 9 speed
Posted by D Slater on January 14, 2009 at 05:14:20 from (71.164.51.74):
In Reply to: Re: MW 9 speed posted by MCMP on January 13, 2009 at 18:43:25:
Don't know what RPM you try to stay at going down track or what the distance is from center of axle to ground with your tires is. But this may give you a idea if I got the math right, in a hurry and didn't double check so you may want to figure it yourself. If all gears are standard M and you was turning 1450 RPM and distance from center of axle to ground is 31.6 in 4th now thats 5.8 MPH. With W6 R&P thats 6.2 MPH. With M&W on high side and standard 1st in M thats 6.8 MPH. W6 R&P is 47 and 19. M&W high range constant mesh gears are 29 driving a 34 tooth.
If you use a W6 R&P get the main shaft bearing retainer with it. If you use the M one you will run into trouble setting gears up.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
