Re: Haban Belly Mower
Posted by mkirsch on January 14, 2009 at 06:19:30 from (64.80.108.55):
In Reply to: Haban Belly Mower posted by teddy52food on January 13, 2009 at 07:34:20:
Never heard of the company myself, but as has already been said, anything can be done with a welder, cutting torch, scrap metal. and a few precision parts. If you have the mower or can get it cheap enough, why not try and see if you can make it work?
Haban is probably one of those small flash-in-the-pan short line equipment manufacturers from the '50s or '60s. Not enough equipment out there or enough of a following for someone to do up a website with company history and technical data. Just orphaned equipment that shows up from time to time in the backs of old farmers' barns.
Hopefully your C has the belt pulley drive, because otherwise you will need about a 18" diameter pulley on the PTO to drive the mower fast enough.
