Re: TRAILERING A TRACTOR
Posted by RockyMO on March 11, 2009 at 18:59:31 from (24.216.122.188):
In Reply to: TRAILERING A TRACTOR posted by RICK IN VERMONT on March 11, 2009 at 15:19:09:
I recently posted about this as well. I had always been under the impression that chains were required for any load on wheels, ie. tractor, car etc. Recently I have been seeing the semis hauling new cars use a nylon strap over the tires. Tow trucks have been using these for years. The Consensus I received from professional drivers is that: Straps are ok if and only if they are clearly labeled with a strength or weigh rating, and sufficent number of straps to exceed the load weight are used. Straps should also be checked frequently for wear, cuts, abrasions etc.
Rocky in MO
