Overcharging Battery on 856
Posted by Overcharging 856 on January 14, 2009 at 09:31:43 from (4.224.78.193):
Right now it has a single 12 volt 1000 amp battery and getting ready to put the two batteries back in. It has developed a problem with overcharging the battery. it charges at like 17-18 volts, the battery gets warm! I run it with the IGN switch off and just keep the battery charged up,,, but will have to rebuild the starter for the first time in 15 years. Has some weird gear clashing in the bendix.
Far as I know everything on the charging system is stock. It has a 1466 cab on it, and going to put on new lights and fix the heater fan.
Where should I start? Might need a diagram, and some part numbers if possible. I dont wanna put the chevy alt on it. Wanna keep it just as it was, original. Key switch went bad,, it has a push/pull from an old M.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
