Here's a pic showing an H4 mag converted. You need to disconnect the mag's coil wire at the points. Then install an ignition switch and an auto type coil. Then run battery voltage to the ignition switch and then to the coil. If your battery is + grounded your hot wire from the switch needs to be connected to the - minus terminal on the coil. Then run another wire from the + terminal on the coil to the points. Unhook the grounding wire on the mag. Be sure to clean those points until shiny. You will need to run a new coil wire from the new coil to the cap on the mag. It should then start. Hal
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
