Re: Super a parts/steering
Posted by Gene Bender on January 14, 2009 at 10:22:20 from (67.55.226.75):
In Reply to: Super a parts/steering posted by Mark W. on January 14, 2009 at 05:55:14:
I get the bearings and the two bushings from the dealer and the seals from Car Quest. You need two bushings,two bearings and two seals i make my gaskest from gasket material. You will also want to replace the key as i mite also be worn. Then fill with 9o wt and they will steer like new. You should use a calipers on the ball ends and i use a disc grinder to make them round again. When done it will be like new again.
