Re: Road Gear on F Series
Posted by the Unforgiven on January 14, 2009 at 10:41:39 from (66.146.251.208):
In Reply to: Road Gear on F Series posted by Tom Stork on January 14, 2009 at 10:24:30:
Real easy to spot, it will be an extra box right on the front of the transmission with a little shift lever of some sort. Most of them were a "road gear", you put the trans. in nuetral and then shift the road gear in and hang on. A Hiesler unit is a dual range, giving 4 more gears all above the standard 4th gear, and much harder to find as a general rule. Any of them for a 30 are a little hard to find.
