New info::: With the tractor not running, turn on the lights (if they work) if the needle on the amp gauge goes to the right, the amp gauge was not changed when the battery was installed Neg ground. (if the lights do not work, a close look at the needle when switching on the ignition will also show this right needle movement, but far less distance on movement. If it moves left with lights or ign, the amp gauge was reversed when the battery was put in Neg ground. So, if it moves right with the battery Neg grond, it will be moving left with the battery in correctly, this is good. If you want it back to normal (stock), turn around the battery, Polarize the gen (as K-Mo below indicates) and you should be good to go. If the needle moves left when lights are on, the amp gauge wires must be moved from post to post inside the electrical box to make it read correctly with a Pos ground (stock) battery hookup. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
