Re: 1950 H engine rebuild advice
Posted by El Toro on January 14, 2009 at 11:26:53 from (64.12.116.73):
In Reply to: 1950 H engine rebuild advice posted by neblinc on January 14, 2009 at 10:11:45:
third party image
You twist that safety wire from one bolt to the other and the Air Force used a tool for doing it and made it very neat. We did it by hand. I don't know why you couldn't use cotter pins they should serve the same purpose. You can prime your oil pump and install it. Once everything is completed in the lower block you can install the pan, timing gear cover and damper pulley. You can install the valve tappets too. Hal
