Re: 1950 H engine rebuild advice
Posted by glennster on January 14, 2009 at 14:26:32 from (76.223.245.56):
In Reply to: 1950 H engine rebuild advice posted by neblinc on January 14, 2009 at 10:11:45:
randy, you can get the saftey wire from your engine guy or machine shop. take an old ice with you for the right size. its not just regular baling wire. when you wrap the bolts,you want the wire routed so it holds the bolts from unscrewing. kind of hard to explain but if you look at them installed imagine one bolt loosening, you want the wire to pass so it tries to tighten the other bolt.
