Re: How to remove top transmission for a 1942 Farmall H
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by DALE on April 03, 2000 at 17:29:10 from (208.170.79.101):
In Reply to: How to remove top transmission for a 1942 Farmall H posted by buster on April 03, 2000 at 16:20:40:
It sounds like the same thing that happened to my super M.Push down on the shift lever and remove the pin that crosses thru it and then lift it out. Use a large screwdriver or small pry bar to line up the slots that the shift lever goes in. The bottom of my lever was worn and I built it up with weld. I have a good neighbor who owns several farmalls and says this is quite common.
Post A Followup
: Re: Re: How to remove top transmission for a 1942 Farmall H
