No No, somebody gave you some miss information. The factory high speed set up is 6 mph 4th or there abouts. The reason 3 & 4 are switched is that they put 4th gear in place of 2nd and moved reverse to the other shaft which gives it a higher reverse too. I might be off on my gear sequence but it's something like that. Anyhow most of the after market road boxes drive with the transmission in neutral. There are a few true overdrives out there too,
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
