Re: Farmall M wont start
Posted by mattofvinings on January 14, 2009 at 17:46:37 from (67.142.161.29):
In Reply to: Farmall M wont start posted by Farmall Zach on January 14, 2009 at 17:22:44:
This does seem to be odd from a parts-change standpoint.
I usually like to start with a slug of fuel somehow introduced into the carb or intake tract. An alternative is the miracle fog - starting fluid but go very easy on that.
Any coughing and attempts to run for a couple of moments indicate you have a spark and timing is correct.
If you just get a wet spark plug (after removing it) then likely a spark problem.
